Electrical Issue
pxt
One circuit keeps blowing a fuse( exhaust fan, dinnette light, front fantastic fan, and outlet). Replace the fuse a few times. What's next? shamrock 183. Thank you!
8 REPLIES 8
MrWizard
Moderator
Moderator
yes, with DC you can have arcing, that exhaust fan (cook top?) can draw 5amps
with other items running an arc on that could go over the fuse limit
i rather he finds a loose wire, than have to trace an intermittent short
I can explain it to you.
1997 F53 Bounder 36s
D_E_Bishop
PTX, have you figured out where the short is yet? I know I'm getting in on this late but if you just go ahead and disconnect everything and put a fuse in, if you don't blow the fuse look for the hot wire, hook up the fixture at that point and the find the next hot.
It is simpler when you don't know how the circuit runs to disconnect everything and then hot up the circuit. If everything is connected and the shortis in the last run you waste a lot of fuses.
I don't think a loose wire is going to blow fuses.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
pxt
Thanks for advice.
MrWizard
Moderator
Moderator
does it blow, when nothing is turned on or plugged in
intermittent short in the wiring
a wire is pinched or a screw is making contact with the 12v hot for the circuit
start with the light and then the outlet
look for loose wires
then move to fantastic fan and stove exhaust fan
hopefully you find a loose wire connection
a pinched wire will be very hard to find
pxt
Just a cell phone plugged in.
MrWizard
Moderator
Moderator
12v outlet ? located where
120v outlet ? for the TV ? 12v would be a control circuit, so the TV can't be used while moving
eieioh
Turn everything on that circuit off. replace the fuse. turn on each item one at a time. the one that blows the fuse is the culpret. If they do not pop the fuse, turn them on together and see which one is the overload.. You are not saying what you have plugged into the outlet. That could be the overload.
This advice is worth what you paid for it.
agesilaus
Get your multimeter out and start looking for a short or other problem.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
