โMay-23-2013 10:54 AM
โMay-24-2013 07:09 PM
โMay-24-2013 07:01 PM
โMay-24-2013 06:35 PM
pianotuna wrote:
Hi,
I hate burning propane--so I tried this today.
I put two eggs (in the shell) inside the four cup drip coffee pot.
I filled it with water, then poured the water into the reservoir.
Then I made coffee and waited 25 minutes.
End result was two nicely hard cooked eggs.
The coffee pot initially uses about 530 watts for seven minutes. Then it cycles once every three minutes for 13 seconds.
I know that 15 minutes was not enough time. I suspect I'll try 20 minutes next time to try to get a nicely soft boiled egg.
โMay-24-2013 06:07 PM
โMay-24-2013 05:53 PM
โMay-24-2013 04:24 PM
โMay-24-2013 03:32 PM
โMay-24-2013 03:24 PM
pianotuna wrote:Yah, *most* of the time. ๐
Why would I burn propane when my solar system will give me "free" energy?
โMay-24-2013 03:22 PM
โMay-24-2013 03:18 PM
2oldman wrote:
What's the problem with burning propane?
โMay-24-2013 02:48 PM
โMay-24-2013 02:40 PM
pianotuna wrote:
Hi bannanadanna,
Can they be used with MSW or will that let out the magic blue smoke?
โMay-24-2013 01:59 PM
bananadanna wrote:
Immersion heating elements are pretty efficient for heating liquids.
We use a Sunpentown 1200w (ten levels) magnetic induction burner. It flips a mag field in any ferrous material ---the pan is hotter than the cooktop.
Approximately twice the energy is transferred to the utensil vs propane.
Great for hot weather, no propane water vapor, much safer in confined quarters.
WM has 1300w models for $65.
How do the induction cooktops work (or don't) with a modified sine wave inverter?
I guess folks from say Port Alberni Victoria find it hard to believe that using a live flame in an RV is not the smartest thing to do when it is hot and sweaty. Using A/C, one stupid stove burner seems to kill off most of the benefits of a roof air going full speed.
Similar to a small microwave in power requirements.
โMay-24-2013 01:53 PM
2oldman wrote:I don't see a problem with it. I burn that stuff all the time. If I didn't, I wouldn't be able to cook or heat my house.
