Engine lights
Sunnyjim245
When checking the oil I found a pair of underhood lights. How do I turn them on?
Thanks!
2005 Bounder 35E Workhorse W22 towing Dodge Durango 4x4
10 REPLIES 10
Sunnyjim245
To close this thread, I found an unmarked switch on the dash that turns the lights on and the utility light as well. Thanks for all your help!
wa8yxm
I will say again. Check the switches on the dash for one marked "Service light" or "Servie lights" mine are controlled that switch. Workhorse chassis, include that in your post as well. (Or whatever chassis it is bu9ilt
Bobbo
If you want that appended to your messages, you also have to put it in your "signature."
Bobbo and Lin
Sunnyjim245
Sorry, I thought my vehicle info would be added to my note automatically. It is a 2005 bounder 35E and i am the second owner. I can find no switch, magnets, etc near or on the hood to turn the lights on. thanks for your help!
westend
Typically controlled by a hood switch. Post make/year/model of RV for more focused advice.
'03 F-250 4x4 CC
KD4UPL
What vehicle are we talking about?
Have you checked the bulbs?
Most under hood lights I've ever seen came on automatically when you opened the hood.
wa8yxm
On my ride there is a dash switch "Service lights" ON some rides a switch on the "Hook" (Engine access panel) does the trick.
BB_TX
Every vehicle I have ever owned that had under hood lights, those lights came on automatically when I opened the hood. Trace the wiring to see if it goes to a switch.
2oldman
Say nice things to them. Check the bulbs.
TakingThe5th
Many times those lights have a motion switch to turn them on automatically when the hood is opened. I'm not familiar with your rig tho so I'm not speaking with absolute authority on this.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
