Everpure head QL3 replaced..
tenn_vol_
I had to replace the QL3 head, and I made a mental note.
I know, that was not a good ideal.
But replacing the new QL3, I think the input water goes
to the back of head then flows with the arrow to the
output which is into the icemaker.
Any help will be greatly appreciated.
Thanks, tenn.vol
3 REPLIES 3
tenn_vol_
Yes, I was originally thinking I remember the output was the
input, as I was remembering the way I took it out.
But as I thought it thru the 1/4 in. line out to icemaker.
Thanks ALL for the input.
tenn.vol.
Jim
Yes, the arrow indicates water flow direction.
Don't know what kind of RV you have but usually the output of the Everpure goes to a goose neck water spout next to the kitchen sink faucet. So you're only using filtered water for drinking and cooking, not dishes, wash water, or rinsing off things. And the ice maker.
After the water spout, the plastic pipe goes to a shut off valve, then onto the ice maker valve behind the refer.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
Jim-Linda
Looking at the head with the turn off lever to the front, the rear fitting is the imput.
