EXTERIOR STEP HANBDLE REMOVEING?
Oasisbob
The handle (left side of entrance door outside) is just yucky after 19 years. Tried cleanser, asetone just not comming clean so thought I sould replace it. How? I am wondering if it is installed at point of construction from the inside. There seems to be no access cover for exterior screws? Any thoughts? I may try painting it?
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
5 REPLIES 5
jdc1
Then there are covers over the screws that slide/pop off.
Oasisbob
My handle is just a handle. It does not swing out nor is it lighter
Oasis Bob
2018 Ford Explorer
HAPPY TRAILS:)
BFL13
The usual swing- outs have screws you can get at. In fact, sometimes you have to tighten them. On ones I have had, the darn foam covering on the handle slides down to the bottom over the years, so that is kind of stupid.
As usual with aluminum RV frames, the screws get so you can't tighten them and have to use fatter screws, which may not be possible where they go through the handle brackets.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
jdc1
Look on Amazon. They show pictures of different handles and where the screws are located.
jdc1
Which handle do you have? The swing out, or the lighted? The covers over the screws slide off on most.
