fantastic fan thermostat replacement
shadoow
my fantastic fan thermostat needs replacing. Has anyone used a regular thermostat instead of the fantastic fan brand, something like a Honeywell from Lowe's or wherever???
4 REPLIES 4
shadoow
Old-Biscuit wrote:
The thermostat is an analog type so should be able to change out with a digital.
But does it also have switch for 'In' & 'Out' direction of fan......mine does.
definitely digital.
My thermostat only has the slider switch on top
called fantastic vent, no free parts just told me i had to get one from a retail vendor
shadoow
Passin Thru wrote:
I'd look at the back and see if the wiring matched up. Shoould work. Our house thermostat has 4 wires, colorcoded to it. Just replaced it.
i figured not all wires would match since the home thermostat has wires for heating and cooling, but maybe i could just use the ones for cooling.
Old-Biscuit
If so you would need to delete that option OR install another switch for reverse/forward control of fan
Why not give Fantastic Vent Company a call 1-800-521-0298.
They use to be REALLY good about sending out replacement parts for free but that was before they were bought by Atwood.
Still worth a free phone call.
Passin_Thru
