Fiberglass Hairline Cracks
Scott_JodyB
After removing a faded decal I noticed that there were very small crack in the surface of the siding that I guess were caused by the removal of the decal. I am concerned about the cracks. You can feel them when you run your fingers over them but they are not raised. Is there something I should do or have done?
5 REPLIES 5
shelbyfv
I haven't used this but folks on the Fiberglass RV forum give it good reviews. MagicEzy
CA_Traveler
Sounds like fiberglass crazing.
2014 Grand Cherokee Overland
Bob
theoldwizard1
Go to a boat repair shop.
valhalla360
Nomad III
Nomad III
Pictures?
Are they cracks or scratches?
If you were using a razor blade to remove the decals, it could just be scratches and yes, you may be able to feel them.
It's not uncommon for fiberglass to develop what's referred to as spiderweb cracking. If it's limited to the gelcoat, it's mostly cosmetic. If goes thru to the glass, it can be more serious.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Grit_dog
Navigator
Navigator
Doubt it.
