Fixing leaking front window (worn exterior seal)
vlopddap
My travail trailer front window is leaking around the frame, by the outside seal which is apparently compromised.
Removing front windows is a pretty straight forward process... remove all screws from the inside frame, then push on the window while someone catch it from the outside. Okay.. fine then.. after you need to deep clean any trace of the old seal on RV exterior wall and window frame. I know the key is a proper surface prep for re-sealing. That's crystal clear for me.
But any suggestion on the re-sealing process and right stuff to use? I saw some old videos on YouTube where people use some kind of putty tape that is applied directly on the RV exterior wall and then the window is pressed against it, but since my KZ trailer is made of rippled aluminium, I would expect something at his more "liquid" to follow curve and fill gap of rippled aluminium body, more like a caulk instead of a putty tape. So what should I use for re-sealing my front window? A specific brand of RV grade exterior wall caulk (not roof caulk as well) or any high quality residential window caulk such as GE window caulk?
Thank you very much!!
2016 Dodge Grand Caravan SE Plus
2011 KZ Sportsmen Classic 16BH
13 REPLIES 13
Not applicable
I'd try a flex steel product
Fisherguy
Chris Bryant wrote:
It all depends on the siding pattern- if the corrugations are too deep, I use 2 layers of butyl tape- I wind up wasting a lot, but it gives a good, water tight seal.
The main thing is to make sure you see some butyl squeeze out along the entire perimeter, then I trim with a plastic putty knife. The seal is the butyl, any caulk added is purely cosmetic, and not to actually seal the frame.
Be aware that the butyl will continue to squeeze out for a bit.
This is what I did when I rebuilt the front wall of our old Nomad.
06 Dodge Ram 3500 Cummins 6 spd std with a few goodies.
2007 Komfort 274TS, 480 watts solar, Trimetric 2025RV, PD9280, Honda EU2000i, Xantrex SW600
2019 Timber Ridge 24RLS, 600 watts solar, 3-100Ah Lithiums, 12volt Norcold Fridge
vlopddap
Mortimer Brewster wrote:
You might not have much access. My trailer had 1 inch of styrofoam sanchwiched between exterior and interior pieces of 1/8" luan board. If the separation is between the styrofoam and luan you could always drill a hole down into the styrofoam from above in order to get the sealant to the void. Then clamp. I'd be leery of using expandable foam as it might blow out the wall.
Well, if there really is a styrofoam somewhere in the front wall it's really not "sandwiched" because if I press anywhere on the wall with my hand (it's not a new behavior, it's the same since I purchase it brand new), the luan is moving very freely, that's why I was thinking the wall use fiberglass insulation or is just empty! I agree that the expandable foam need to be used carefully, but are you aware you can purchase a specific low-expansion foam which is intended for use in enclosed spaces? I agree that the traditional expansion foam would be very dangerous to use since it's strong enough to lift a concrete floor!
Thanks for your advices!
Mortimer_Brewst
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
vlopddap
I had the same problem on my KZ. The window openings are oversized, the window being held in place with compression. This leaves a gap beneath the window. Over time the bouncing/vibrations of road travel take their toll, and the window shifts downward. This leads to small gaps on the top corners where water can intrude.
My solution was to shim the window up using some PVC trim that custom cut to fit. Be sure not to shim it so it's centered in the opening. This will prevent future sagging of the window. Nothing more than butyl tape is needed.
I would also inspect your other windows. If a window has sagged the butyl tape will leave a trace of it above the window. If you see this I'd go ahead and reset the window.
Thank you so much for this valuable information Mortimer! I would definitely check for any loose fit of the frame into the wall when I'll remove the window to fix the sealing and make the appropriate shimming.
I'll also check if I found some way to reinforce from the inside the very thin luan of the inside wall because when water spill around the window framing, it made a small "bubble" in the luan of about 3x3 inches and when it dried up completely the luan was cracked a little bit in the bubble and it's weird because it feels like if the wall is totally empty behind luan, like to isolation or nothing... so when Iโ€™ll remove the window I assume I'll have some kind of access to inside the wall and spray some expandable urethane behind the "bubble" to ensure if someone push on it it wont damage the wall...
For now the window is not leaking anymore because I made a quick "emergency" seal from outside the frame with RV caulk and it's 100% sealed for now. But now I need to make a more permanent fix to the seal. ๐Ÿ™‚
Thanks again for your advice!!
Chris_Bryant
-- Chris Bryant
Mortimer_Brewst
vlopddap
firemedic08 wrote:
Yes, just one layer, and yes middle bottom is where I Started and Stopped. I can see the Argument Coming from some, for using Caulk on it after also, but I didn't do it. I had no more leaks from that window. It was leak free up to the day I got rid of it (both of them).
That's a good point! What I can still do is after installing the butyl tape, I can still apply a extra coat of a sealant around the exterior frame of the front window with RV grade wall caulk?
firemedic08
Donnie
1994 Chevy 2500 Extended cab
1987 28 ft travel villa 5th wheel.
vlopddap
firemedic08 wrote:
I used it on a Rippled Aluminum sided Prowler camper,
and a ripple sided Sunline TC, but Not my current 5th.
Wow, this is awesome! And just a single layer and that's it? You just screwed back the window (from the inside frame) in place and that's it?
I assume the best place to make a single joint where the tape is beginning/finishing is on the middle-bottom of the window?
Thanks again!
firemedic08
Donnie
vlopddap
firemedic08 wrote:
Amazon link of what I used.
This is what I used.
Thank you very much, but did your 5th wheel have fiberglass or rippled aluminium wall? Because I can't see how this thin butyl tape can fill the large gap between ripples when the actual seal (a black stuff) is at least two time thicker than this butyl tape? Do you put two layers of this tape?
firemedic08
Donnie
