โMay-18-2018 08:31 AM
โMay-19-2018 10:23 AM
โMay-19-2018 07:53 AM
โMay-19-2018 07:23 AM
โMay-18-2018 10:00 PM
โMay-18-2018 06:09 PM
โMay-18-2018 06:06 PM
โMay-18-2018 05:40 PM
โMay-18-2018 04:51 PM
pnichols wrote:
However, your idea of going 12V to 12V directly using the RV's built-in charger/inverter is very interesting. You might have to hand-make a special cable with a male 12V plug on each end to be able to easily go from RV 12V receptacle to cab dash 12V receptacle........
โMay-18-2018 01:33 PM
โMay-18-2018 12:38 PM
DrewE wrote:
If you have a solenoid based battery combiner that's controlled by the engine run circuit, you can just put the key in the run position (without starting the engine) for a spell to connect the batteries and give the chassis battery a little boost. I often do this when exercising my generator during storage periods. Yes, it does leave the engine computer and vent fan and so forth energized, but if you're on shore power that's no big deal.
โMay-18-2018 12:32 PM
โMay-18-2018 11:17 AM
โMay-18-2018 10:41 AM
โMay-18-2018 08:43 AM
time2roll wrote:
Depends if the cigar plug is switched with the ignition or always on.
Seems a bit makeshift compared to Trik-L-Start battery combiner.
โMay-18-2018 08:35 AM
