โMay-10-2017 06:14 PM
โAug-20-2017 06:47 PM
โAug-20-2017 05:41 PM
โAug-02-2017 01:38 AM
โMay-15-2017 12:15 PM
โMay-15-2017 12:01 PM
โMay-14-2017 10:49 AM
weschaney wrote:
Hi guys, i just acquired a 1991 27' fleetwood class c rv. It sat for about 8 years before i bought it. I've since drained the old gas, new fuel filter, trans flush, motor flush and new battery. It fired up and ran like a champ for about 300 miles. Now I'm having a issue where after driving for about 5 miles and reaching running temperature it bogs down so bad it won't down shift and will eventually stall if you try to accelerate at all. After it sits over night it runs strong, for about 15 min.. then gradually bogs down till i have to pull over. revs fine in natural, so this is a issue under load. I took it to a trans shop, they said not a trans issue in their opinion, feels like a clogged cat to them. i removed the cat, still has has the same problem. any ideas?
THANKS FOR ANY HELP!!
โMay-14-2017 08:23 AM
โMay-14-2017 06:15 AM
โMay-13-2017 08:59 PM
โMay-13-2017 04:49 PM
weschaney wrote:
Jim, it bogs and bucks, in neutral i can control the rpm fine, only when under load (in drive) it starts to buck and bog. The more research i do I'm finding a difference between fuel pressure and fuel volume. in some instances you can have good pressure, but the pump can be so clogged the volume is compensated thus starving the engine of fuel. kinda weird and hurts my head. I plan on testing the pressure while driving today. Thank you for the info.
โMay-13-2017 04:33 PM
โMay-13-2017 02:48 PM
weschaney wrote:
The trans will shift manually, what it feels like is the motor starving of fuel and not reaching RPM high enough to shift on its own.
โMay-13-2017 01:45 PM
โMay-13-2017 01:36 PM
