Fresh water inlet spring thingy broken
Wrace
1997 Nash TT.
The spring thingy in the fresh water inlet that holds on-board pressure when using the pump finally gave up the ghost this last week, and it of course no longer holds pressure when the pump is on.
Are these things replaced as a complete unit from the outside? If so that seems like it could get tricky depending on if there is much (any) slack in the tubing such that the fitting can be pulled out enough to get access to the tube clamp. It also appears that this fitting is behind the shower tub (naturally) so access from inside may be dubious at best.
What about a redneck repair? The connection is water tight when a pressurized water hose is hooked to it, so why not build a little stubby hose piece or some other combination of fittings to stick in there? The plastic cap of course does not hold pressure.
What say you?
Thanks
21 REPLIES 21
newman_fulltime
Old-Biscuit wrote:
YES you buy a new complete assembly
Called a 'City Water Inlet'
CW has one on sale.........HERE
I just advertised for CW :S
please write to old- biscuit for all and every refund from this point on
midnightsadie
now thats a quick fix, and theres a wal mart on every corner, old biscut just had a senior moment.
Dutch_12078
The quick "fix" is to just screw on an inline hose shutoff. They're about $2.50 at the nearest Walmart or home improvement store.
Dutch
2001 GBM Landau 34' Class A
GMandJM
Too funny!
Keep that up and you're going to get drafted as a a moderator.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
downtheroad
OK Biscuit, I'm calling a meeting, but I am pretty certain that you are going to be kicked out of the club because of your actions..
Being a senior member you should know by now that it is your duty to disparage and complain about CW!!!
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Old-Biscuit
newman_fulltime
they are not that much and not that hard to replace
