Fresh water tank.
WWBELL
I'm new here and not sure if my problem belongs here.
I just returned from a trip where I had to use my fresh water tank in my Evergreen 5th wheel. I had to fill before moving to my campsite and topped the tank until it was over flowing.
We ran out of water in 2 and a half days. Normal usage has always been 4 days. Took the 5th wheel and filled again, topping off as before. Both the filler and air vent had water coming out.
We used very little water but everything acted as if we were empty.
I thought the pump was bad. I bought a new one, installed it. No change.
The sensors on the tank were showing 1/3 both times.
After the first fill they showed full. After the 2nd fill they showed 2/3rds.
I got home opened my tank drain and a large amount of water came out. I would guess some where between a 3rd to a half a tank.
Does anyone have any ideas?
Could it be the pickup line?
I cannot access the tank from above.
It will be a huge project to drop this tank and I physically can't do it, so I.E expensive repair.
Any help or ideas would be appreciated.
WWBELL
13 REPLIES 13
Fulltimer50
It could be helpful to know the year and model of your rig.
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
RJsfishin
This post is very correct, (except for the psi)
If a vent hose gets water logged, and runs more vertical than horizontal, it can cause a real problem in filling.
I have that problem existing in my current MH.
When it happens I use a 6" pc of hose in the vent ext fitting. and simply blow the vent line clear of water,....it doesn't take much human pressure to clear it. I always threaten to remove the (what must be) sag in the vent line, but never do.
But this still has nothing to do w/ the OP not able to draw water off a tank that is 1/3 to 1/2 full.
I would still believe there is access to an inline filter some where.
Just a caution,....don't ever put more than even 2 to 3 lbs pressure in a flat sided plastic tank,....and even that mite be too much.
Fletch Rider wrote:
I had a very similar experience. Began to occur after I had filled the tank and then towed the camper. I eventually cupped my hand around the water inlet and basically pressurized the tank until the vent line spit out water and then there was a sort of burbing and air began rushing into the vent line and all was right with the world again. I can't see the entire vent line, so the only thing I can think of is water was sloshed into the vent line while traveling and sat there until I forced it out. You could probably use air to make sure the vent is open as opposed to forcing water into the tank. But be careful not to use greater than 35 psi regardless of which approach you try or you'll have a much bigger problem on your hands.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Fletch_Rider
WWBELL
Wow, Thanks everyone. Lots of great ideas. If there is a filter it's not visible which means dropping the tank. Of course the tank is hidden by some kind of sheeting on the bottom of the frame rails and runs the full width between them, which also has the rear jacks assembly and and the spare tire rack mounted over it attached to those frame rails. Thanks again. If anybody has any other ideas please speak up. I have reservations at a shop for next Friday and I can already hear my bank account crying.
RJsfishin
I had a new MH constantly plugging the filter w/ plastic curly Qs from the hole saws drillings. I didn't think it would ever quit, but over a years time, the plugging got fewer and farther between
And yes, if your sureflo pump ever starts sounding strange like a rattlin sound, don't wait too long like I did,....go out and tighten the screws before the pump falls apart. Probably not a common thing, but I had one do it also.
Rich
wa8yxm
IF you live in the great frozen north... one of the things often overlooked when winterizing is the water pump inlet filter and housing. It can crack if overlooked,
I've never had your problem.
BUT... I have had some screws on the water pump work a bit loose (high vibration area) and the result was it sprayed water all over when it was running, this greatly increases consumption.. I finally figured it out and tightened it down but the water runs out the hole in the floor into the wet bay and then onto the ground so it's hard to spot.. I had the access panel open for some reason when it happened and saw it.
Lynnmor
RJsfishin wrote:
Maybe you missed this part ?
W/ 1/3 to 1/2 tank full, and no water flowing, I'd go after the filter/plumbing.
Lynnmor wrote:
I would fill the tank to overflowing, and then drain it, but this time measure the amount coming out. Without knowing if the tank is getting full there is no point in doing plumbing work.
With the gauges not reading right and no way of knowing how much water is actually in the tank, there is no way of troubleshooting an unknown. We don't know if the tank was filled at one location and used at another. I have some ideas, but won't offer anything more till the actual contents are reported.
RJsfishin
Rich
Lynnmor
RJsfishin
Any sight of a filter in the pump intake line ? You never mentioned one word of a filter,....first place I would look.
Rich
DrewE
It could be pickup line positioning or blockage in the tank.
I suspect it could also be an air leak somewhere around the suction side of the pump, maybe an antifreeze suction line valve that isn't quite closed or a loose fitting.
the_bear_II
I've heard of pieces of plastic floating around in the tanks; these are pieces left over from molding of the tank or trailer construction. Some are small but not small enough to be sucked up by the pump others are large (openings for hoses, fill pipe, vent ...etc. These pieces as the tank empties can block the pickup line then when you fill they float away from the pickup line.
The only way to fix this would be to access the tank, try to remove the debris or change the pickup end so it's like basket with multiple openings.
icanon
Not sure but could it be a air lock? (air in water line).
Loving wife and 2 beautiful daughters.
Chocolate Lab, Lily
2014 Dodge Ram Laramie Hemi 5.7 with 3.92
2014 Dutchmen Kodiak 290BHSL
ProPride 3P Hitch
Progressive Industries EMS-PT30C
Love my Weber Q1200
Me a Happy man on retirement!!!
