Fresh water use
oldtrojan66
I have noticed that I can have a full fresh water tank (65 gal in my JAYCO 36RLTS) when I pull into a site with water available. When I hook up to this “city water”, after some period of time the water in my holding tank is gone. Is this a siphon issue, or is it supposed to be that way? I have separate valves to open or close for “city water”, “city water fill”, “normal”, “winterize”, etc.
Thanks for the help!
David
2007 Jayco Designer 36RLTS
2006 F350 DRW 6.0 PSD (powerstrokehelp.com)
When you're born, everyone is smiling and you're crying. Live so that when you die everyone else is crying and you're smiling!
19 REPLIES 19
Ron3rd
Your condition is not normal. So "No" is the answer to your question.
Equilizer Hitch
Honda EU2000
wa8yxm
IF you use a water regulator the pump may kick in to supplement
In some parks again the pressure in the city line may be less than the pump pressure
You may also have a leak
This is in addition to the above comments Turn pump off when hooked to city and see what happens,
STBRetired
Did you turn the pump switch off? If the city water pressure is less than the "on" pressure for the pump, the pump will run and deplete your onboard tank. Do you hear the pump running when you open a faucet?
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
enblethen
Valves are in the wrong position. Check owners manual. Label in compartment should show correct valve positon for city water usage.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jaycocamprs
If I understand your post, the NO it should not do that. And I don't understand how it is happening unless the pump is on, and is running as you use water. Or you have a leak.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
