โSep-15-2015 10:04 PM
โSep-16-2015 06:52 PM
imgoin4it wrote:
The lady at one park ask if I had "one of those things" between my cord and the pedistal and if I did I should remove it because they cause problems.
โSep-16-2015 06:51 PM
smkettner wrote:
Also consider carrying a sacrificial 10 to 20 amp portable battery charger to charge direct from the pedestal. Less money than a voltage booster as long as you can run on battery.
โSep-16-2015 02:43 PM
โSep-16-2015 01:26 PM
โSep-16-2015 11:05 AM
โSep-16-2015 10:37 AM
fitznj wrote:
"100# water pressure..........GOOD REGULATOR !!! "
My thoughts exactly........ a high water pressure reading does not make it "good".. With those numbers. I would disconnect the water each time I leave. This kind of pressure will blow apart the water fittings - I would not trust the regulator (in this instance), I've had one which partially failed and took out a water fitting.
Gerry
โSep-16-2015 09:51 AM
โSep-16-2015 08:18 AM
โSep-16-2015 07:20 AM
โSep-16-2015 06:40 AM
โSep-16-2015 05:37 AM
โSep-16-2015 05:20 AM
โSep-16-2015 04:59 AM
โSep-16-2015 04:47 AM
