Nov-17-2017 05:56 AM
Nov-17-2017 02:57 PM
Gjac wrote:
What kind of stuff would grow in your cells filled with acid?
Nov-17-2017 02:45 PM
Nov-17-2017 02:42 PM
Nov-17-2017 02:27 PM
Nov-17-2017 12:54 PM
Nov-17-2017 12:10 PM
Nov-17-2017 11:37 AM
Gjac wrote:
I have always used distilled water but when it is 4 degrees out and your distilled water bottle is frozen solid I figured warm tap water was good enough. What kind of stuff would grow in your cells filled with acid?
Nov-17-2017 11:31 AM
ScottG wrote:I have always used distilled water but when it is 4 degrees out and your distilled water bottle is frozen solid I figured warm tap water was good enough. What kind of stuff would grow in your cells filled with acid?Mandalay Parr wrote:
Should always use distilled water.
X2.
Did that and learned an expensive lesson back in the day. Stuff grew on the tops of cells like weeds - and we have soft water.
Nov-17-2017 10:57 AM
Nov-17-2017 10:40 AM
Nov-17-2017 08:11 AM
Gjac wrote:I think you are fine for now. Does not sound like there was a hard freeze in the cells.
They are holding a charge for the last 5 days.
Nov-17-2017 07:19 AM
Nov-17-2017 07:17 AM
Nov-17-2017 07:13 AM
Nov-17-2017 06:58 AM
