furnace won't light
ford_coupe
Good chilly morning to all. furnace in our 5'er won;t light,worked ok till last nite. as far as I can see no way to get to it,in cupboard under sink. no access out side,just vent & exhaust. checked propane both tanks have plenty stove burns good. any thoughts b/4 I call mobile repair?
6 REPLIES 6
ford_coupe
`had rv repair guy come,crawled into area had me turn up thermostat & funace came on, thinks I had air bubble in line. thanks to all for your help
enblethen
You need to locate the make and model of the furnace!
It is possible that it is dirty and needs to blown out or vacuumed good. The sail switch maybe inoperative. Could be bad circuit board or high temperature cut out.
It is hard to say with out make and model to help.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
docnascar
HTH
RV FURNACE TROUBLESHOOTING
Good luck
Tow Vehicle
2017 Chevy Silverado 2500HD
6.0L gas. Double Cab
Travel Trailer
2020 Grand Design 2400BH
ford_coupe
ron 3rd.blower comes on, no heat can't see any circuit board, will check propane bottles, 5'er is 2008
Ron3rd
What model furnace? Does the blower come on but no heat? If so, it could be the sail switch. Blower does not come on? If so that's a different set of potential problems including a bad circuit board.
Most are remarkably simple in design and operation and there's only 2-3 things that ever go wrong with them. If you can see the circuit board and it's a newer generation furnace, it will have LEDs on it that flash an error code. You can then look up the code in the manual. If you can get access to them, they're normally pretty simple to fix once you figure out what the problem is.
Equilizer Hitch
Honda EU2000
Ranger_Smith
I actually had an issue where my stove would light but furnace wouldn't because tanks were near empty. Lift the tank to make sure there is plenty of propane in it.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
