Gassing
TomG2
Do flooded wet cell batteries only produce gas when being charged? Can they be charged outdoors and then placed inside a camper for use powering fans, etc. safely?
19 REPLIES 19
TomG2
pianotuna wrote:
The sealed jars are valve regulated. If the pressure becomes too high they vent. Hence the need to stay just below the gassing voltage, when recharging.
Are you saying that they only give off gas when charging and in fact at higher voltages?
BFL13
So how can you recharge them to full without reaching gassing voltage? They are not AGMs.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
pianotuna
Nomad III
Nomad III
Regards, Don
BFL13
What is the gas emission story on Wet, sealed batteries VS Wets with removable caps?
Photo in Profile
SidecarFlip
The gas both ways, charge and discharge. Chemical reaction.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
