pianotuna wrote:
Hi,
It is winter time. I only run the generator to exercise it. It is a Yamaha 3000 sIEB.
Should I turn off the fuel valve and let it shut down after being starved of fuel? (This risks dried out seals?)
Or
Should I merely turn off the fuel valve and turn off the generator with the key?
I have a Yamaha 3000 iSE (no boost), and I always turn it off at the fuel petcock. Been doing this since October of 2011, and have had no issues. The generator usually starts on the first pull or a second or two with a key.
As for gas, I've experimented with SeaFoam, Sta-Bil, and Star-Tron. SeaFoam didn't work out for me, and I ended up having to drain the tank and fill with fresh gas so the generator would take a load without stalling. Sta-Bil works decently, but with cheap gas, I noticed some surging. Right now, I'm experimenting with Star-Tron, although I've "over-medicated" the patient with too much additive the past couple weeks... but have had very good results. So, for gas, I'd use Chevron Premium and Star-Tron additive.
Fill-wise, I can get two complete tanks done on around $25 of gas, and $1 of Star-Tron, so it costs me $13 per tank (20 hours if running the generator on econ throttle to charge the battery, ~8 hours if running the A/C.)
For storage, I definitely turn the generator off at the petcock and let it run dry, after making sure to run the generator with fuel preservative. I'm sure there is some fuel left in the bowl, but I'm too lazy to drain it. Every 3-4 weeks, I run the generator at 1/2 load for a bit (mainly to keep the other RV subsystems in good shape during the hot Texas summers.)
If I were letting the generator sit, I'd follow the user manual, drain the fuel tank, change the oil, fog it (OnaGuard from Onan) change the air filter (with a new one that is properly oiled), add a tablespoon of oil down the spark plug hole, yank the cord a time or two (make sure it is off and the petcock off) to spread the oil out, and call it done. The battery for the starter, I think doesn't need much upkeep, but it might be wise to disconnect it.
All and all, I've had very good luck with the Yamaha generator. My next rig will have an inbuilt Onan, but I definitely will keep the Yamaha generator because it is so reliable, likely have a place for it to sit on my solar trailer, so I have a fast way to charge the trailer's batteries (thinking 2-3 pairs of 6 volt AGM golf cart batteries so I have at least 500 amp-hours without going below 50% SOC on any jar.) if the trailer's panels don't put out enough energy to keep the batteries topped off. I also like the fact that the generator is acceptably quiet (which is the second biggest reason I bought it -- when it is chewing on the load of an A/C, it makes less noise than Honda twins, although Hondas make far less noise when idle and Eco-Throttle is on.) Of course, I'm happy with the fact that unloaded, it puts out 122.4 volts... and it drops to 119 volts when I fire up the A/C, without any major surges or sags.
