โJul-28-2022 05:30 PM
โJul-29-2022 09:44 AM
ReneeG wrote:
Thanks! We have two eu2000i we parallel for AC mainly. I read that gasoline provides more power than propane, and even though we will be installing a SoftStartUp, your comment is one to consider regarding. We've always had one Honda 2000 mainly for backup, but have never had to use it with our solar setup. The goal of two was for the AC in the rare instance that we really need it at lower elevations. We had one instance dry camping near Jackson, WY over the Labor Day weekend that it was so hot we were miserable. It's nice to know that with the two, should we ever need it for backup for the house, we can.
โJul-29-2022 06:40 AM
valhalla360 wrote:ReneeG wrote:
Thinking of converting our gasoline to propane or tri-fuel using the Hutch Mountain conversion kits for Honda eu2000i.
If you are trying to get away with a generator that is marginal, the power loss will matter, so a 2000w honda derated for propane may no longer handle air/con.
If you are just charging batteries and other light loads or you buy a mores substantial generator suited to the heavier loads, it's a non-issue.
Fuel cost seems to be pretty much a wash. A gallon of gasoline will run longer but costs more. Slight hassle getting fuel as actual fill stations are less common than they used to be but we only run on generator 3-4 times a month.
We picked up a champion 4500w unit for $800 earlier this summer. Other than a bit of a fiasco having amazon deliver it, we have been quite satisfied. It barely comes off idle running the air/con and as a quick test, I ran the air/con plus a small space heater and it handled it easily (not that I would suggest doing it regularly).
The real reason in my mind to get a propane unit is to avoid gummed up carbs. If it wasn't for that, gasoline would be the way to go.
โJul-29-2022 06:38 AM
ktmrfs wrote:ReneeG wrote:
For those of you that have dual or tri-fuel generators, what has been your experience between gasoline and propane and/or natural gas regarding power and running time length? I read an article today that summarized that running a generator on gasoline provides more power whereas running on propane is cleaner (understandably). Was it worth the extra expense investing in a multi-fuel generator? Thinking of converting our gasoline to propane or tri-fuel using the Hutch Mountain conversion kits for Honda eu2000i.
with the engine designed to run on gasoline max power output in order
1) gasoline
2) propane
3) NG
as far a clen burning and oil contamination
1) propane or NG
2) gasoline
I've converted my honda 2200 and 2000 to tri fuel from hutch mountain.
Why??
In the case of power outage assuming NG is still at the house I can run forever on NG, and I usually have 25 gallons of propane for various house stuff (firepit, heater, etc.) along with 30 gallons of propane for the trailer, but usually only about 5 gallons of easily available gasoline. (yes I could syphon from the cars)
BTW I never use propane out camping, seldom need more than a full tank of fuel in the generator so that's enough for the campout.
โJul-29-2022 05:54 AM
โJul-28-2022 07:59 PM
โJul-28-2022 07:22 PM
โJul-28-2022 07:18 PM
โJul-28-2022 06:25 PM
โJul-28-2022 05:35 PM
