Generator Oil Onan
AJR
My rig is a 2011 Four Winds 28A
I have a 4KW Onan generator built in to it.
When I remove the generator dip stick after sitting for days it shows no oil. If I screw the dip stick back in and remove it. It shows half full. I have done this about five times because the results are so, so, worrying.
Do I need to add oil?
2007 Roadtrek 210 Popular
2015 GMC Terrain AWD
2 REPLIES 2
Kayteg1
You must have one of those dipstick with long tube and well sealed cap on top.
Those create vacuum, or pressure in the tube depends on temperature, so the readout first time doesn't count. Pull the dipstick, wipe it off, reinsert and then check.
Muddydogs
If dipstick is showing half full then it's half full. pull the dipstick and shine a flashlight in the hole or stick your finger in the hole and see if there is oil if you don't believe the dip stick. Oil should be an inch or so below the top of the dipstick hole.
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
