โNov-19-2021 08:50 AM
โNov-19-2021 05:05 PM
Bobbo wrote:
50 amp unit is 12kw.
30 amp unit is 3.6kw.
So two 50 amp units plus one 30 amp unit is 27.6kw. Divide that by 0.8 to get the power needed to allow the generator to run at 80% capacity for longevity and you get 34.5kw. Note that this is maximum. You probably can get by with significantly less.
A single 34.5kw generator will probably be more expensive that having 3 smaller generators, one for each RV. Also, having the 3 smaller generators means you are not totally without power to all 3 RVs if the generator conks out.
My vote is a smaller generator for each RV.
โNov-19-2021 04:45 PM
โNov-19-2021 04:06 PM
โNov-19-2021 01:54 PM
โNov-19-2021 01:34 PM
โNov-19-2021 12:56 PM
โNov-19-2021 12:05 PM
โNov-19-2021 11:52 AM
โNov-19-2021 10:46 AM
TFin04 wrote:pianotuna wrote:
Equip all three rv's with hybrid load support inverter/chargers.
Acquire a 6000 watt inverter generator.
I would pick a champion.
Alternately get two Predator 3500 watt generators. They can be combined together to provide power to the RV's.
6000w is enough to power all three? Interesting, I was thinking it would take more than that.
โNov-19-2021 10:35 AM
โNov-19-2021 09:46 AM
