Generator Vibration/Noise Isolator----FOLLOW UP...
Jay_Pat
Follow up on previous post-
Original POst
I purchased these isolators.
Rubber Isolators
My tool box fits inside an angle iron frame.
I put rubber isolators under the tool box. The tool box does fit against the angle iron on the sides (No room for rubber on the sides of the tool box).
Inside the tool box, I have the generators sitting on plywood. I placed rubber isolators under the plywood and bought a rubber mudflap to cut up and place around/inbetween the plywood edges and the tool box. So, the plywood is completely isolated with rubber.
This has helped greatly with the resonating of sound in the rv. It has also cut down vibrations inside the rv.
It didn't completely stop the problem. It's just a lot better. The wife was happy with the improvement.
If I need to do an improvement, I'll add to the angle iron frame so that the tool box sides have nothing to touch.
I hope this is helpful to anyone that is having problems or anyone thinking about building this type of generator setup.
Pat
2010 Ford F-350 SRW
2021 Grand Design Reflection 315
2 REPLIES 2
joshuajim
A single layer of plywood makes a great sounding board (think piano). To minimize this, laminate 2 sheets of different thickness together. They resonate at different frequencies and cancel each other out.
RVing since 1995.
rkentzel
Try some of these they work better
These are multi layered and work pretty good
1997 Pursuit class A
