GFI circuit drawing down whole camper.
djpetrou
I need some suggestions here.
2004 Trailhauler toyhauler.
One circuit has gfi receptacles at the kitchen sink, the bathroom sink and at the cook top.
When this circuit is on it draws the battery down an will drain it. This happens even when hooked to shore power. It is a considerable drain when turning the breaker on and off.
I am suspecting a GFI maybe or with the age of the unit maybe the converter.
Any suggestions on finding the problem?
D.J.
30 REPLIES 30
ScottG
Unless your running the GFCI circuit off an inverter powered by your battery, there's no connection between the GFCI and your battery.
