โMar-19-2014 07:16 AM
โMar-20-2014 08:05 AM
โMar-19-2014 08:05 PM
aruba5er wrote:Yup, I have one of those air-over-water systems. No problem pressurizing the system, even easier for winterization.
you can't build pressure with a diapharm pump. when it runs dry it's dry. Those pumps are not compressors. Unless you have a really old system that had an air compressor. Haven't seen those since the mid 70's
โMar-19-2014 07:28 PM
โMar-19-2014 04:04 PM
โMar-19-2014 03:44 PM
myredracer wrote:
It's okay to be paranoid, but only when it comes to water leaks in an RV. ๐
You could go to HD or hardware store and buy a pressure gauge and a few fittings. With a compressor you could charge the entire system to say 50 psi and let it sit for a day or two and periodically check the gauge. It should not drop over a day or two. This is the only way to know for sure and it's how piping system in new houses get tested.
If you did happen to have a problem, the PEX piping will be okay and it'd be a fitting, valve or faucet (or pump if it had water in it) that could be damaged.
'Course, make sure the fittings for testing you put together don't leak, lol.
โMar-19-2014 12:37 PM
โMar-19-2014 12:03 PM
bgum wrote:
Sure fire method to find a problem is to go camping. If there is one it will let you know.
โMar-19-2014 11:35 AM
โMar-19-2014 08:34 AM
โMar-19-2014 08:21 AM
โMar-19-2014 08:14 AM
Bobbo wrote:
Close all water outlets, turn on the water pump. Let it sit. If the water pump occasionally comes on, you have a pressure loss (water leak) somewhere.
โMar-19-2014 07:47 AM
