Gray water hose....
KPotter44
Hello all.....new to the forum. We recently purchased a 2008 Pastime 840LT truck camper. After going through all the tie down stuff and the other things associated with putting a camper on our truck, we have questions about the gray water clean out. It seems the gray water valve is a different size than the black water valve. The cap on the gray water valve says 1 1/2". So I have to drain the black water, close that valve, and then hold the 3" hose up to the gray water and then drain that. Does anyone offer a hose that will attach to a 1 1/2" valve? Thanks. Keith
9 REPLIES 9
wa8yxm
Well.. Normally all RV drains are 3" but... That said.. Perhaps someone messed with yours.
That 1 1/2 inch line, is it threaded? If so try reducing it to a garden hose fitting.. Then you use a GRAY garden hose (I have white, gray, black and green here) to hook it to an adapter to the drain
Camping World Link to the Adapter
Bumpyroad
RJsfishin wrote:
Bumpyroad wrote:
get a cap to fit the grey water outlet that has a standard hose fitting on it. just use a garden hose to drain.
bumpy
But I've never seen that either. If all else fails, not hard to drill a hole in the cap and thread/epoxy a garden hose fitting into it.
they certainly are easily available for the larger sized pipe. if not, can easily fabricate one using a short fitting with garden hose on one end and NPT on the other with locknut?
bumpy
RJsfishin
bumpy
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
old_guy
I think Bumpy has the easiest and cheapest solution to draining the tank
Reddog1
Moved to Tech Issues.
Wayne
Moderator
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Bumpyroad
bumpy
KPotter44
Thanks for the responses guys. I have discussed this with a few folks and most say their gray water drains out through the same hose as the black water. It makes sense to have your gray kind of flush your hose for you, but not this rig. Will attempt to post a pic.
kohldad
Welcome to the Forum. It would help if you let us know the camper model and year. You can do this by adding the info to your signature.
A picture would help too. Here is a link on how to if you do not know how: How to Post Picture Info
Usually, the 1-1/2 valve and 3" valve is tied together for a single 3" hose connection. Or the 1-1/2" is adapted to 3" for the dual connection points.
Have never seen a 1-12" sewer hose, but I'm still learning.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
thetroutman4
Maybe a 1.5" to 3" adapter? This is a new one on me! Good luck!
