Headlights not working on Beaver Baronet 1991
Mike_Charman
Gentlemen, I am on the road and far from home. Today in daylight but raining I discovered that my headlights are not working. Fuse is good and all sidelights brake lights etc working Ok Any body have a wiring diagram for this ?????. Any and all tips gratefully received. The wiring diagram would at least make it so I could "Jury Rig" so that I had lights permanently. Email address is mike@salemtravel,com or my cell 6189180249.
Thanks folks. Mike
1 REPLY 1
Brian_B1
I have seen a loose or corroded ground wire kill headlights. I have no clue on your particular vehicle, but they are typically a short wire coming off the back of the headlight and screwed to the radiator support somewhere. Might be worth a look if you can get out of the rain.
96 coachman catalina 198CB Ultra-Lite. 19'-11" long, 7'-10" wide, and 8'-9" tall (plus AC) as well as a borrowed truck.
