โNov-24-2018 06:57 PM
โDec-05-2018 11:55 AM
โDec-05-2018 10:53 AM
โDec-01-2018 05:05 PM
โNov-26-2018 11:33 AM
โNov-26-2018 10:10 AM
โNov-26-2018 09:02 AM
MEXICOWANDERER wrote:
I'll spell it out...choose one...
Bad design--crummy materials
insufficient load capacity
BUT IT ISN'T THE HEADLIGHTS
It's the tail lights and markers that go out. And the problem is within the switch. Idiots limited the circuitry to carry
Parking lights
Single (pair) tail lamps
Four upper clearance lamps
Switch on a push pull headlight switch on a Ford. Set to high beam. If you have a rig with say eight extra lamps, squeeze the extended knob stem after fifteen minutes. OUCH.
Brilliant
What do overheated breakers do?
Carry less amperage
Carry more amperage
DOT ratings specify a temperature for circuit breakers integral with headlight switches.
I've diagnosed far too many examples of this to have been fooled.
Use a Tyco circuit breaker and ease the misery and perhaps avoid a "your fault" collision at night.
Newer automobiles and rigs use circuit breakers and relays. Problem solved. Big Rigs use common feeders and as many as three tower type (White Rogers) relays to feed tractor, semi and trailer. I had to upgrade a bunch of triples in Nevada for Jartran. NVDOT was ready to shut down the fleet.
โNov-25-2018 09:04 PM
โNov-25-2018 06:34 PM
โNov-25-2018 03:14 PM
dougrainer wrote:MEXICOWANDERER wrote:
Start and Stop
The OEM headlight switch is overloading and the integral circuit breaker is tripping. Unbelievable. Ford had this issue 38 years ago and never fixed it.
Either patch it up with a new headlight switch replacement
Or add a relay to power the small BROWN wire the exits the cab and powers tail and clearance lamps.
You Tube
Tail lights relay installation.
Really, Ford had a supposed issue 38 years ago and you state it must still be an issue????? There are tens of millions of these Ford switches out there. IF there was a supposed defect, don't you think there would be a great outcry on this supposed problem? The simple fact is, the OP has a 18 year old Headlight switch that has failed from 18 years of current flow. Just replace it, NO BIG DEAL. Doug
โNov-25-2018 02:44 PM
โNov-25-2018 02:40 PM
โNov-25-2018 02:13 PM
โNov-25-2018 05:32 AM
Start and Stop
You Tube
โNov-24-2018 07:22 PM
