Attwood gc10a-3e
azbohunter
Attwood gc10a-3e Have intermittent starting on gas, works fine on electric side. I have cleaned all the terminals and applied some dielectric grease to them. It seems if it is continuous use it works but if I turn it off for a day or two, it most likely will not fire up when turned on. If I turn it on and off 2-3- maybe 4 times it usually starts. I have been told if the board was bad that it would probably not start at all? Any thoughts?
I need to add that before I cleaned all the terminals it wouldn't fire at all so leads me to believe there is still something not making good contact?
2006 Dodge Quad Cab Cummins 5.9 Automatic 4x4
2002 28RKD Lakota fifth wheel
Pullrite Hitch
2006 Polaris Ranger
16'Lund w/50HP Merc tiller
A great wife who loves to travel and fish
I love to archery hunt/she joins me and cooks!
9 REPLIES 9
azbohunter
ScottG wrote:
Dielectric grease will never make a connection better. Get everything working first and then slather that stuff on if you must.
I have gone through this step twice, first time I was camping when I started having issues, I cleaned all terminals and connectors best I could with a small wire brush and one of my wife's emery boards. Did not help. When I got home I did the same procedure again only using emery cloth and removing the igniter and using the emery cloth on the probes.....I also using pliers pinched all the female connectors tighter so assure a better contact, THEN I applied dielectric grease hoping it would help to prevent future issues with connectivity.
Pullrite Hitch
2006 Polaris Ranger
ScottG
BFL13
Old-Biscuit wrote:
"Yes, orifice. Leave tube on the intake and fill with mineral spirits and blow --should squirt out."
Not on Atwood.
Orifice screws into body of gas valve
Suburban orifice is on burner tube
Sorry. Yes, on my gas only Atwood, I got the orifice off and it has a "hollow" at the intake end which held enough spirits that I could squirt it out. (have to spit after that! ๐Ÿ™‚ )
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Old-Biscuit
Not on Atwood.
BFL13
azbohunter wrote:
BFL13 wrote:
Intermittent start on gas is a sign that the gas side needs a clean, not the electric contacts. Sand-paper the ends of the igniter probes (all three) and use mineral spirits to clean (soak in a jar or can) the sprayer. The sprayer will shoot mineral spirits like a little water pistol when it is clean.
I have cleaned the probes and the grounds, not sure what you are referring to as "sprayer""? Orifice maybe???
Photo in Profile
azbohunter
Pullrite Hitch
2006 Polaris Ranger
azbohunter
Old-Biscuit wrote:
Propane and electric are completely separate systems on that model
Propane side is all in outside compartment and exposed to the elements.
It is a 2002 model....16 yrs old
Corrosion/resistance play havoc with 12V DC current
Also good clean/tight ground connections are a must
I think I will go back over all the electrical connections and even replace some of the connectors. I have the tools to do that.
Pullrite Hitch
2006 Polaris Ranger
BFL13
Photo in Profile
Old-Biscuit
