โDec-03-2018 12:45 PM
โDec-05-2018 01:25 AM
โDec-04-2018 04:48 PM
angler wrote:
The service you mentioned on Honda's is required service, but it's at 100,000 miles not 60,000 and I think only the V6. The 4 cylinder has a Timing chain instead of a belt. It's about 800 ( Not exactly sure) Certainly not 2000. They replace the internal belt, water pump (have to take it off anyway), and a few other things as part of the process.
All the New Dealers do this now for maintenance. They make much more on service and Parts than selling cars. Its a shame since many people get taken
โDec-04-2018 04:11 PM
โDec-04-2018 03:34 PM
boston blacky wrote:Probably not a good idea to base maintenance, especially if still under warranty, on a WAG;) Someone mentioned that you may not get the change alert. The dealer should be able to explain if that's the case. Could be why they mentioned it.
I figure fluid should be good for (at least) 50k to 80K miles.
โDec-04-2018 02:36 PM
โDec-04-2018 02:33 PM
time2roll wrote:
First three years it will be brake fluid and wipers. Really hard to up sell when you do not even go in for service.
โDec-04-2018 01:29 PM
โDec-04-2018 12:43 PM
pauldub wrote:
I looked in the owner's manual for you and didn't not find any service interval for diff fluid. It does say to replace it when the maintenance minder displays code 6. They are called the Stealership for a reason.
โDec-04-2018 10:47 AM
Ozlander wrote:ppine wrote:
Changing the fluids when you are supposed to is one of the ways to get to 300,000 miles.
Another way is to change nothing and still get to 300K.
โDec-04-2018 09:52 AM
โDec-04-2018 09:24 AM
โDec-04-2018 08:31 AM
โDec-04-2018 08:14 AM
โDec-04-2018 05:56 AM
