Heater keeps dying
cummins93
Hello,
I am borrowing a friends camping trailer (keystone cougar), and I am running into a issue with the heater. When I turn it on it will run normal for a few hours really good, then it will shut off and not kick back on unless I turn off the thermostat and turn it back on and it works after that. I am wondering what that might possibly be. I basically have to reset the on/off switch on thermostat. Any help is MUCH appreciated!
Thank you
6 REPLIES 6
midnightsadie
you can pull down a battery in one night,
cummins93
Thank you all very much for the replies, I looked and noticed the batteries were getting a little tired.I replaced them and so far no issue. I guess I should have started at the basics. I did not realize those heaters were that finicky with the voltage. I surely appreciate the help!
BFL13
Had that issue, turned out to be the tstat. Got a new one, no more of that. It would be blowing cold air at night. Turned off tstat, wait for blower to stop, turn it back on, got heat, back to bed. Repeat. ๐Ÿ˜ž
RVing is fun if you don't weaken!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
midnightsadie
battery will not last long running by itself. furnace really eaats up battery life. if plugged into shore power should be no problem,
ksg5000
Are you connected to shore power? Are you using your propane heater vs electric heater? The std propane heater for an RV requires fully charged battery and they are designed to shut off if the power gets low. Common for rigs to loose heaters when batteries get low.
Kevin
wolfe10
Are you plugged into shore power (to keep the batteries charged)?
The furnace runs on 12 VDC. Low voltage can impact operation.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
