โApr-02-2009 05:50 PM
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
โDec-31-2011 07:52 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โDec-31-2011 04:40 PM
โDec-31-2011 02:34 PM
scootsk wrote:
I wanted to write in reference to EU2000 generators. I purchased the EU2000 and companion in August. Just in time for the hurricane and no lights for 3 days. The both performed beautifully. After the storm, I let them sit for two months. I went to start them this week and they wouldn't start. I came to RV net and found this thread. I cleaned the both carbs, changed the fuel. The first started right up, the other no such luck.
Today Long Island was 58 degrees, perfect weather for troubleshooting the generator. I pulled the carb again and sprayed the sh*t out of it. Put it back together nothing. Pulled the carb spray cleaner and compressed air, put it back together nothing. I picked up the gennie and held it in front of my French doors and was going to throw it through. Cooler heads prevailed.
I did a search and saw that EU2000i gennies are notorious for stuck intake valves. Pulled the plug put in my finger pulled the cord, NO COMPRESION!! Time to split the case and pull the valve cover on my 4 month old gennie. Lo and behold the intake valve is frozen. I pulled the rocker and started tapping the valve with a punch. I got it to start moving, sprayed it with carb cleaner and kept working it until it moved freely. Put ti all back together. Pulled the cord, started one pull!! Yahoo--I wanted everyone to know this in case they came across the same problems after cleaning the carb..
โDec-31-2011 11:47 AM
โDec-31-2011 11:13 AM
โDec-19-2011 07:33 AM
popeye59 wrote:
I don't have a Honda generator, but I have dealt with those poorly designed nuts in plastic before. If you can gain access to it, try wedging a small jewelers type screwdriver in alongside the nut. Put some epoxy on the nut when you reassemble to help keep it from happening again.
โDec-18-2011 09:25 PM
โDec-18-2011 08:57 PM
โSep-09-2011 08:11 PM
โJul-06-2011 10:40 AM
Almostthere wrote:
Good review and procedure for cleaning carb jets on Honda. However, how do you get the jet out if it does not "fall" out once the threaded plug is removed. I gently tried to use a welding tip cleaner to get it to drop out.........no success. Obviously you need to be careful not to disrupt the orifice in the jet.
โJul-02-2011 01:39 AM
โJul-01-2011 10:56 AM
โJun-02-2011 09:18 AM
brbo wrote:Thanks for the link.
Not this brand but similar I just glued it to the case and ran the wire into plug access. I got it more to monitor eng hours but tach is handy too.
http://www.tinytach.com/tinytach/index.php
Toad: 91 Zuke
โJun-01-2011 09:44 AM
โMay-05-2011 06:48 PM
