โNov-14-2016 04:06 AM
โNov-16-2016 04:45 AM
โNov-15-2016 01:52 PM
oldtrojan66 wrote:
Sorry to upset you, Doug. My Buddy does not need to be educated. He told me the very things you mention. There is debris in the valve causing it to mix too much cold water. Until I get this part cleaned properly, my wife and I are very capable of mixing our own cold water to avoid burns. As an added precaution, i have installed a lower temp thermostat in place of the relay that was there. I had 151.2 water, and now have 133 water by measurement. I am prepared for the lower volume of hot water this mod gives.
By the way, I'm sure, had I mentioned the model number many of you would have told me just what my Buddy told me only based on knowing the maker. At least the problem is now solved to my satisfaction. Thanks again, David
โNov-15-2016 01:19 PM
โNov-15-2016 10:50 AM
oldtrojan66 wrote:
Ok, the fix is in! I talked to my buddy at Walnut Ridge RV service in New Castle, IN just a few miles from my home.
He had heard of this problem with some other units in the past. Turns out, Atwood is the only manufacturer who puts a "mixing valve" in the plumbing. They don't do it anymore, but the one I have, has this device. It is used to heat the water to a higher temp, then add cold as it is dispensed. Well, when it malfunctions, it just adds too much cold!
Now, you may disagree, but I have removed this device. I do not have one in my B & M home, and since other makers don't use it and Atwood doesn't either, I can add my own cold water to get the temp correct.
Thanks again, for all your ideas. Good ones, I agree, just something else this time. David
โNov-15-2016 10:18 AM
โNov-15-2016 04:33 AM
โNov-14-2016 08:53 PM
โNov-14-2016 07:02 PM
westend wrote:
Be careful of scalding. I've forgotten what temperature the hot water is at with an Atwood with mixing valve but it is definitely hotter than the ones without. Your house water is not that hot.
โNov-14-2016 06:41 PM
โNov-14-2016 05:43 PM
โNov-14-2016 02:37 PM
โNov-14-2016 01:35 PM
fpresto wrote:
If you have an outside shower make sure that the faucet handles are off not just the shower head. If open they allow the hot and cold to mix.
โNov-14-2016 12:27 PM
oldtrojan66 wrote:
Thanks for the replies! I forgot to mention I have been around the check valve block several times. It is working as designed. I have removed the entire water heater when I thought I would need to replace it. When there was nothing wrong found, I replaced the unit, and checked the valve and the plumbing around the heater. I understand how the check valve works for winterizing and it is a normal in-line gate valve with one red handle to move the internal parts 90 degrees. All that is okay. I understand the check valve is the first place to look, and I have done that. I have also checked the outside shower (which has never been used) and it is turned off. I'm just saying, the only thing that gets me a full tank of useful hot water is to drain part of the water out, refill with the air space at the top and reheat. I just don't know why this is so. Thanks, again, david
โNov-14-2016 09:31 AM
