Jun-25-2013 03:32 PM
Jun-26-2013 08:43 AM
RJsfishin wrote:Again agreed. I'm thinking about the Progressive Dynamics PD9245C with built in charge wizard.
For about the same money, why would you choose a battery charger over a 4 stage converter that is designed to do this job ? A converter is designed,....filtered, etc, for staying inline all the time, a batt charger is not.
Jun-26-2013 08:29 AM
Unyalli wrote:RJsfishin wrote:Agreeing with you. On this subject would it be better to disconnect the built in converter/charger and install a quality battery charger close to the battery?
Yes, a converter is nothing more than a glorified battery charger, and hook up is exactly the same.
In my Rockwood the WFCO 8955 power center is located around 15 to 20 foot of 10 gauge wire from my batteries. Disconnecting the built in converter would not remove power from the distribution panel would it? If not I would rather get a good adjustable 3 or 4 stage battery charger and mount it close to the batteries with 6 or 4 gauge wire. What say you?
Jeff
Jun-26-2013 08:22 AM
BFL13 wrote:
You are allowed to have two. Just install the new one up front and leave the old one as is. Let them run at the same time. The new one will do all the work anyway, with its higher voltage. You could also unplug the 120v cord on the old one so it won't run, but leave its DC wiring alone
Jun-26-2013 08:03 AM
Jun-26-2013 07:23 AM
Jun-26-2013 05:22 AM
Jun-25-2013 07:35 PM
Jun-25-2013 07:16 PM
Jun-25-2013 06:19 PM
Jun-25-2013 05:48 PM
Jun-25-2013 05:38 PM
Jun-25-2013 04:39 PM
BFL13 wrote:
Read this and then decide:
http://home.earthlink.net/~whemme/
Jun-25-2013 04:32 PM
Jun-25-2013 04:30 PM
Jun-25-2013 04:29 PM
MEXICOWANDERER wrote:None of the converters will. I've tried three different one's (borrowed WFCO 55 amp cause mine wouldn't boost, Paramode 55 amp that actually did 58 amps and IOTA 55 amp that does 53 amps). All required supplemental charging using another unit. They do get close though, close enough to make you think batteries are fully charged and the IOTA and PD's occasional stirring probably removes some sulfation or eventually charges close to full while removing some sulfation. At least that's my theory. I do enjoy the IOTA's occasional 15 minute, 14.7V stirring. It saves me having to do it manually. Maybe some of the higher end programmable inverter/chargers can get there. Don't know. I don't own one to test one out.
ARE THERE ANY so-called smart chargers around that are plug-and-play?
