โMay-23-2016 01:59 PM
โMay-27-2016 06:50 AM
โMay-27-2016 06:13 AM
Huntindog wrote:Okay, that's not the most ridiculous thing I've ever read, but it's pretty darned close.
The first big problem here is that there are only two kinds of grease seals. Those that leak, and those that will leak.
That's right. There has never been a grease seal made that won't fail at some point.
The next problem here is that WHEN a grease seal in the easy lube system fails..... It is unseen. It is most always discovered after the damage is done.
So for those of you that are giving good reports on using this system... I am happy for you now.
But at some point your seals WILL fail too. It could be next week, next year or the year after. For all you know, they may have failed now.:E
โMay-27-2016 04:11 AM
โMay-27-2016 04:06 AM
โMay-27-2016 02:20 AM
โMay-26-2016 07:28 PM
โMay-26-2016 07:21 PM
BB_TX wrote:Likes to tow wrote:
Are you guys kidding me???? Is this post real???? For those who used several tubes to grease your bearings on an EZ Lube system I know where your grease went!!
Pull the brake drums and look at your brake shoes. EZ Lube axles were primarily designed for boat trailers that get submerged in water. The RV industry picked up on this "easy care-free" idea as a marketing tool. You guys are in serious trouble when you need your brakes!!!!!
You know nothing about where my grease went. I comes out the front of the hub just like it is supposed to do, just as shown in Dexter videos. Have used the EZ Lube system 3 times since new (8 yrs)and brakes still work like new, and no grease on them.
Another one who simply does not know how the system works.
โMay-26-2016 07:16 PM
fj12ryder wrote:Likes to tow wrote:Yeah, I just pulled my wheels/hubs and they were fine. Do you actually have the EZ Lube system? Or are you just parroting what you've heard?
โMay-26-2016 06:35 AM
โMay-26-2016 05:29 AM
dmansellpc wrote:
I just greased mine for the first time and had no problems. Lifted tires with Lippert 6 point and spun the tire while pumping 1 tube per hub.
โMay-26-2016 05:23 AM
โMay-24-2016 05:54 PM
โMay-24-2016 01:15 PM
โMay-24-2016 12:52 PM
fj12ryder wrote:
If the Pennsylvania inspections are anything like the Missouri inspections, they mostly go through the motions. And they pull every brake hub? What do those inspections cost? Missouri inspections are $10-12, but we also don't have trailer inspections.
Also, FWIW, it isn't hard to pull the hubs without getting grease everywhere. Basically the grease is in exactly the same places as it would be with a regular hub, just a bit more of it. And not really that much more. A non-issue IOW.
โMay-24-2016 10:43 AM
