Sep-26-2018 05:11 PM
Sep-27-2018 04:19 PM
mapguy wrote:mrgrim007 wrote:Lynnmor wrote:ChuckSteed wrote:
you need to take your RV to a qualified place
Do not take the RV anywhere till you have jacked up that wheel and checked for excessive play and roughness. If you find that, have it repaired on the spot.
If you would have removed the wheel and pried off the hub cap, it wouldn't have been damaged so much.
Thanks for all of the responses. I’m going to leave it where it’s at (next to my house) and inspect it there. I picked up some red grease from HD. I’m not sure how to tell if anything is bad and needs replacing, but I’ll Google it or post back here with more questions.
Hopefully, the red grease you mention is Lucas Red-n-Tacky. If so -that is a great grease for trailer wheel bearings.
Sep-27-2018 04:07 PM
Sep-27-2018 10:02 AM
Fulltimer50 wrote:Yeah me too. It's very likely with the hole in the rubber cover that water has gotten in there and washed some grease out onto the wheel. I would definitely replace the rubber cover and check out the condition of the bearings. It's possible, albeit unlikely, that the bearings have gotten hot and liquefied enough grease to run out and coat the wheel. Whatever the problem, deeper investigation is in order.
I would like to know how you people can say anything about the bearings from the pictures shown.
Sep-27-2018 08:31 AM
Sep-27-2018 08:24 AM
Sep-27-2018 07:57 AM
Lynnmor wrote:Looks like specular highlights in a flash picture to me. But I won't assume. The OP can tell us if it's metal.
That metallic color looks like a serious problem.
Sep-27-2018 07:41 AM
Sep-27-2018 06:50 AM
Sep-27-2018 06:47 AM
Sep-27-2018 06:19 AM
mrgrim007 wrote:
Took the cap off and this is what I found:
Sep-27-2018 04:56 AM
Sep-26-2018 09:24 PM
Sep-26-2018 06:35 PM
Sep-26-2018 06:04 PM
