Humming Noise in Electrical Cable Area
USMC46
I am hearing a humming noise in the compartment that stores my 50 amp cable and it's reel. I unplugged from shore power and the noise is still there. You can hear it from inside the bedroom. My coach is a 2004 Dutch Star. Any ideas what this is ? Normal ? Thanks.
Jim & Carmel
2016 Escape 17b
2017 Jeep Cherokee Trailhawk With Factory Tow Package
6 REPLIES 6
Valkyriebush
do a search for ATS (automatic Transfer switch) humming, lot of info on the forum about this. possibly your issue.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
KATOOM
If you have a generator then I'm sure its the transfer switch (gen/shore switch) making a humming noise. Pretty common for some transfer switch models. Sometimes you can take the contact points apart and clean them up to see if that helps (power off obviously) or look for a better model less likely to hum.
kiwiiam
I had a Dutch Star for a few years, I had similar, It was the Power Converter/charger - that rig has a seperate Inverter/Batt Charger. The Charger was in a compartment under the bedroom slide. The fan was going and making a noise - I replaced the charger.
Kiwiiam
Elipse
Silverado
wa8yxm
Fan on converter trying to cool it down, Fan is a 12 volt device.
Crickets
aruba5er
Battery disconnect Switch? Neighbors Jayco has a relay disconnect switch.Needs power to hold it closed. Quite (no power) when off.Should have been a latching relay so power is only needed to make the switch. Don"t know if that is what you are hearing though
dougrainer
Possible the Converter Fan is running which will run even after 120 disconnected until the converter cools down. If you have an Inverter/Charger, you will not have a Converter. The standard Converter is in the shore cord Compartment on a Newmar. The optional Inverter is on the Passenger side. On your Newmar in that compartment you have
The Transfer box
The Converter/s if you have them, your model may have 2 converters
The Power Cord reel
The BIRD control relay(this will not make any noise)
The Emergency Start solenoid
The Battery disconnect Solenoid Doug
