Nov-03-2016 06:47 PM
Feb-16-2017 08:56 PM
time2roll wrote:
I can't imagine 3000w sine wave inverter struggles to start your air.
My Prosine 1800 run the air better than utility power. (RIP)
My replacement GoPower 2000w has no issues either.
Mine is a 12 yo Dometic 13.5. Inverter has 5' of 4/0 cable to the four aging GC2.
Could you need a start cap or something?
2oldman had the same issue and ended up with some monster 48v inverter.
Feb-16-2017 06:16 PM
Feb-16-2017 05:22 PM
Feb-16-2017 09:10 AM
ctilsie242 wrote:
This is definitely something I'm looking at doing in whatever rig I get, although Magnum Energy the way I'm leaning. I'm looking at the 3000 watt hybrid inverter, a monitor panel, a generator controller, and a battery temperature gauge. This way, if the power conks out on my rig with the A/C on, the batteries take over until they fall to 60% SoC, then the generator controller fires up the Onan. Power comes back on, the generator stays on until the batteries are at 90% SoC, genset drops offline, transfer switch flips to shore power, life goes on.
One big advantage of a hybrid inverter is that the locked rotor amps coming from the A/C are handled by the inverter and batteries. This doesn't add a strain onto the generator or anywhere upstream of the inverter, so power cords are not affected. The second big advantage is that power sags at a crowded campground are handled and are not passed onto the A/C's compressor which can burn out if it encounters too little voltage. The third is that you can have power coming in from shore power, a second vehicle alternator, generator, or solar... and still run the A/C on a combination of any or all (well, assuming the incoming power is adequate, of course.)
Feb-16-2017 08:52 AM
Feb-16-2017 08:39 AM
Feb-15-2017 03:44 PM
Nov-07-2016 09:11 PM
Nov-07-2016 04:17 AM
Nov-06-2016 09:59 PM
Nov-06-2016 08:46 PM
Nov-06-2016 08:21 PM
Nov-06-2016 07:07 PM
Nov-06-2016 06:57 PM
Micro-Air wrote:New members are restricted from links to reduce spam.
(Note - I had trouble embedding links and the post kept being shown with all of the links "removed". Not sure why.).
