โSep-12-2016 09:22 PM
โSep-15-2016 08:25 PM
โSep-14-2016 07:25 AM
โSep-13-2016 09:32 PM
โSep-13-2016 08:46 PM
โSep-13-2016 07:41 PM
BFL13 wrote:
" I just have two group 27 batteries (all I can fit in the battery compartment of my truck camper),"
Just a note: I found I can get two more batteries each side of the truck bed up front between the wheel well cover and the front of the bed each side, and still slide in the camper, to add to the two I can get in the camper itself.
This gives me a potential of six batteries to haul around when using the TC.
Note: I cut a hole in the left side by the corner of the camper down low, and put in a "cable hatch" to pass the wires paralleling the "outside" batteries to the "inside" batteries.
I do the connections when the camper is part way slid in, and then finish sliding it in. Works great! ๐
โSep-13-2016 07:19 PM
โSep-13-2016 06:45 PM
โSep-13-2016 06:44 PM
agwill wrote:Careful, or SoundGuy will try to lecture you about "choice."
For about $5-10 at a yard sale you can buy a old peculator and make your coffee on the stove.
โSep-13-2016 06:32 PM
SoundGuy wrote:hedge wrote:
I am doing exactly that with the PSW 1000w inverter from Canadian Tire. I have a mr-Coffee Keurig that is under 1000w. When making coffee it uses about 85amps but only for about a 45-60 seconds per cup.
hedge - what battery resource are you using to power your CT 1000 watt PSW inverter? :@
โSep-13-2016 05:33 PM
โSep-13-2016 11:36 AM
โSep-13-2016 11:29 AM
โSep-13-2016 11:23 AM
SoundGuy wrote:
It's called "choice".
mike-s wrote:
Very good, you learned a new word. Now learn what "suggestion" means.
โSep-13-2016 09:00 AM
