Installing a backup camera, need help
Kentucky_Bill
I bought a backup camera and monitor for my truck. Have installed everything, but need to run the wires to the power source on my truck to power up the monitor and camera which I mounted on the rear bumper of my truck. I am at a total loss when it comes to where I should run the wires. I have 3 wires; one red for power, one black for ground and one blue that is supposed to be wired into the backup lights that will turn the camera on when I put the truck in reverse. I think I have found a ground for the black wire but I have no idea where I should run the other two wires. Help:?
Bill & Brenda
06 Ford 250 Lariat Short Bed 4x4
Pullrite Superglide Hitch
05 Holiday Rambler Savoy 29RKS
4 REPLIES 4
Kentucky_Bill
fcooper wrote:
One possibility is to splice into the positive and ground wires for the cigarette/cigar lighter.
There will be a wire for the backup lights somewhere under the dash, or you can splice into the wire at the backup light and run a wire forward.
My preference is to leave the blue wire disconnected. With the blue wire connected, you will find that the monitor almost blinds you when you get into the vehicle after dark and begin to back up.
Fred
I followed Fred's advice and spliced into the cigarette lighter's positive and ground wires. The camera works great using this power source.
Bill & Brenda
Tachdriver
On mine, the transmitter was wired to the back up lights positive wire and negative to ground. The monitor has a cigarette lighter plug in, I never keep in full time as I only need it when docking to trailer.
fcooper
Fred
Fred & Vicki
St. Augustine, Florida
gatorcq
Red is B + (battery).
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
