2007 Itasca Suncruiser with Intellitec EMS. Problem is that EMS control display never shows connected to 50 amp service . It only shows connected to 30 amp service even when connected to 50 amp service. I have confirmed full 50 amp 240 volt connection at main panel. Read where the control board had issues with burned resistors and so I bought and installed a new control board. No change. I have confirmed proper wiring connections to control board.
It acts like the board is never seeing one leg of the 2 hot leads of the 50 amp service. I do not find any dedicated direct wiring to each hot leg to the control board. Does anyone know where the Intellitec control board picks up the 2 hot lead signals so it can detect when connected to 50 amp service?
I also have a PI 50amp hard wired EMS on the incoming power line that confirms both legs connected and shows amp draw on each leg when connected to 50 amp service. I just need to confirm both hot legs signal to Intellitec control board, but cannot see where it is supposed to get it. -- Thanks-- Mick
2007 Itasca Suncruiser 35L
2000 Jeep Wrangler
