โDec-31-2016 05:14 AM
โJan-01-2017 12:07 PM
โJan-01-2017 10:29 AM
TomG2 wrote:
Comparing the Champion 3500/4000 at 68db to a 80db construction generator is comparing apples to oranges.
โJan-01-2017 09:32 AM
bikendan wrote:
i own the Champion 3500/4000 generator you're recommending and it is NOT appropriate for campgrounds!:E
โJan-01-2017 01:40 AM
โDec-31-2016 09:42 PM
Boon Docker wrote:
^ The OP's question is about an inverter generator to charge the batteries not a noise construction generator to run the AC. Just saying.
โDec-31-2016 05:38 PM
RobWNY wrote:
So my power requirements will be likely be Furnace fan, Refrigerator fan, the LED lights, water pump, Slide out when arriving,
โDec-31-2016 04:24 PM
โDec-31-2016 03:59 PM
โDec-31-2016 12:32 PM
โDec-31-2016 11:26 AM
SoundGuy wrote:RobWNY wrote:
My Travel Trailer has the one Marine/Deep cycle battery and I have decided to get 4 Trojan 6V T-105's and wire them in Series and Parallel. I also plan on buying a portable Inverter Generator so I can re-charge the batteries during my stay.
Why would you bother with 4 T105s if you plan to also invest in a genset for recharging the batteries? :h A pair of those 6 volt jugs would cover most common situations for at least a day or two, even power a mid size inverter if you'd like to run a small coffee maker, toaster, etc. Since you'd have a genset for recharging having four instead of two 6 volts really doesn't buy you much advantage, especially considering that most trailers will easily accept two 6 volt batteries but often require some imagination to mount four. K.I.S.S. ๐
โDec-31-2016 10:47 AM
โDec-31-2016 10:24 AM
โDec-31-2016 10:20 AM
time2roll wrote:
2000 should also run the microwave if needed. .
โDec-31-2016 10:09 AM
RobWNY wrote:through camper.
Is it better to charge batteries directly from the generator to the batteries using a battery charger or through the camper by using the RV plug?
RobWNY wrote:If your conservation is good enough you won't need a genny. But then you have to live like a tenter.
I will be conserving power of course and may not need to charge them up,
โDec-31-2016 10:05 AM
Oasisbob wrote:
We can go three nights on our twin g 27 recharging on fourth day using our quiet reliable HONDA EU 1000. I would stay away from cheap copy cat generators. Not as quiet or reliable though they are working on db levels I suspect their measurements are deceitful
