Jeep Libery 4WD Shifter Issue-Help
USMC46
I am towing a 2006 Jeep Liberty behind a motorhome. Tonight when I was hooking up, the shifter that engages the 4WD became very loose and would not shift. I crawled underneath and felt above the differential. The cable has come off the differential. It feels like a Cir Clip has fallen off. I was able to get it to neutral so I can tow it until I can get to a Jeep dealer for the right clip to keep the cable attached. My question is this. Is it safe to tow now that it is in the correct place (neutral)? Or can the differential (4WD) shift into another position if the cable comes off going down the road ? It seems to me like it would be OK to tow, but if the cable comes of again, can it shift by itself (road bounce for instance) when it is not connected to the shift lever in the drivers compartment ? Normal towing configuration is: 4WD in neutral, Transmission shifter in Park, key turned to one click before dashboard lights come on (freeing the steering wheel). Need to get on the road early in the A.M. No Jeep dealer where I am, and no auto parts store close.
Jim & Carmel
2016 Escape 17b
2017 Jeep Cherokee Trailhawk With Factory Tow Package
3 REPLIES 3
ChooChooMan74
Common problem, as I read in lostjeeps.com. Get it fixed when you can.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
USMC46
Yes, I guess "transfer case" is what I should have said. Thanks.
Jim & Carmel
2016 Escape 17b
sch911
First off it's come off of the transfer case not the differential. If the transfer case is in neutral it's safe to tow.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
