โMay-09-2016 08:39 AM
โMay-12-2016 08:17 PM
โMay-12-2016 07:41 PM
fj12ryder wrote:
^^^^^^^^^^^Can't believe they don't have a "Thumbs Up" emoticon. ๐
โMay-12-2016 03:44 PM
โMay-12-2016 09:57 AM
corvettekent wrote:
Just think green. Your diesel fuel cap is green and at the fuel station the diesel hose will be green. How would your generator gas get in your diesel?
One gallon of gas mixed with 50 gallons of diesel is not going to kill your diesel engine.
โMay-12-2016 09:53 AM
โMay-12-2016 09:43 AM
mlts22 wrote:
...For 3+ days, I have a Yamaha 3000iSE, and several five gallon gasoline cans, and that would go on a hitch mounted cargo rack.
My intent was to make sure, by some procedure, that the stuff in the gas cans didn't wind up anywhere than the generator,...
โMay-12-2016 09:28 AM
โMay-12-2016 09:01 AM
โMay-12-2016 08:21 AM
โMay-12-2016 07:56 AM
creeper wrote:
He already has a propane generator on the RV.
โMay-11-2016 07:30 PM
SaltiDawg wrote:ol Bombero-JC wrote:SaltiDawg wrote:JayGee wrote:
I would use the propane gennie. Problem solved.
Couple of hundred dollar conversion kit for your existing gasoline generator... uscarbs.com for a start.
No need for a "kit" - or $200...:(
Send 'em your carb, it comes back in about 2 weeks modified for Tri-fuel.
The carb is returned "modified" - along with a regulator and the necessary fittings. (Guess that kinda makes it a "kit" also, LOL)
Cost was about $100.
May be more now - but liked their "program" better than US Carb.
You can do the same thing with uscarbs.com
A possible advantage to the uscarbs approach is that instead of drilling the carb, you have the option of slipping their "snorkel" - essentially a donut with a propane hose embedded - between the air cleaner and the carb body. Typically takes just a few minutes. If you want, you can return the generator to factory condition by simply removing it.
I have no experience with the other outfit, but you can read up on the uscarbs approach at their forum: US CARBS HELP FORUM
โMay-11-2016 11:38 AM
โMay-11-2016 12:40 AM
A 20# propane bottle equates to about 4 gallons of gasoline. If no propane, replace gas cans with brackets for 20# cylinders. (I have no RV experience, just propane generator experience.)
โMay-10-2016 11:52 PM
