landyacht318 wrote:
as no doubt at some point this issue will return.
Well it returned.
The spring turned to mush. Turned from chrome colored steel to a fully compressed springless piece of coiled steel, which looked galvanized.
The 10 amp glass fuse has a couple drips of solder pushed out from between endcap and glass. It had no continuity. But the part designed to fail, looked perfect.
there was no damage to the plastic housing. I replaced the spring, I replaced the fuse. I use a small narrow diamond dremel bit to cut some teeth onto the ground springs so they grab the receptacle tightly.
But I also ordered a Blueseas locking plug and receptacle. It arrived today.
Kind of impressed with the design.
For your viewing pleasure:
The ground spring is one piece.
It has a rubber seal right at the edge of where the two meet.
The set screws are designed to crush the wire.
The receptacle has detents to help lock the plug in place. It can still be removed from the plug when in these detents, but it requires more force than elsewhere in the plug, and more force than any other plug I've ever used. Not sure I am buying the twist to unlock claim. That requires even more effort to remove the plug than pulling it straight out
The rubber seal is also very tight. I'd believe the splash proof claims. With this plug inserted fully, water is not going to get inside. Not really a factor in RV usage, but between the rubber seal and the locking feature, there is no way the nipple spring is going to push the plug out of the receptacle, even in a high vibration environment
