โJun-28-2015 04:39 PM
โJun-29-2015 05:24 AM
Trackrig wrote:
Something for you to check. We got a drip in a rainstorm also. When I climbed up on top, I found the boot sealing the coax where it goes down through the roof had come loose. I'm assuming cranking the antenna up and down, which moves the cable, caused the boot to work its way up a little and therefore let the rain in. I put a little silicone inside of the boot, slid it back down, and now the boot stays in place and no more leaks.
Bill
โJun-29-2015 04:18 AM
wildtoad wrote:
If it's a winegard there is a procedure for lubricating the gears and rubber seals. The seals can dry out and cause a drip usually at the handle.
โJun-28-2015 05:15 PM
โJun-28-2015 04:46 PM
