Leak from hot water heater
work2fish
Hi Folks,
I've been having a great time with my new camper this summer. I especially like that I can just stop anywhere to camp and do this on a whim since everything is packed and ready to go.
I noticed that when I had my hot water heater on, there is a constant dripping of water drops coming from one of the spigots, here:
It only drips when the hot water heater is on. I'm guessing that this is not normal, but the only way to fix it would be to put some sort of plug in that spigot. Can anybody tell me why this might be happening?
Thanks,
Mike
2011 Ford F-350, KR, 6.7L, 4X4, SRW, short bed
2007 Northstar 850SC truck camper
2002 Lund Fisherman 1700 w/ Suzuki DF140
32 REPLIES 32
Reddog1
DO NOT PUT A PLUG IN THAT SPIGOT. That "spigot" is a safety valve. It is designed to leak when the pressure in the tank gets too high. It is not unusual for them to leak. Usually, after removing the red cap, you just flip the the lever a couple of times, to allow the pressure valve to reseal. Best done when thew water is cold. If it continues to leak, replace it.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Buzzcut1
Nomad II
Nomad II
pressure relief valve. spring might be old or there is crud around the seal. easy enough to replace the valve
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Reality_Check
Nomad II
Nomad II
Replace the valve.. It's your pressure relief valve. Shouldn't leak.
Same thing you have on your typical house WH.
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
