Lithium Battery heater
deadticket8
I seek information on what others use to heat batteries when it is cold. I am leaning towards 12 volt heating pads of some kind. I am not sure how warm my battery compartment stays when the heat is on. And it wont be on when traveling. Is there a pad with a built in thermostat? Can anyone recommend reasonably priced 12 volt thermostat(under $40). Thank you in advance.
20 REPLIES 20
3_tons
Get yourself a wireless Thermometer with remote sensors from Amazon, place one sensor on the batteryโ€ฆ
3 tons
StirCrazy
Navigator
Navigator
I was looking at THESE but I ended up mounting my battery inside the camper so the furnace keeps it warm. I may concider these when I do the 5th wheel. these are low power so you would definatly have to have the batteries in a insulated container for them to be effective.
you would also need somthing like THIS to controle them.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
John_Burke
Go to an automotive parts house. Battery plate and battery wraps have been made for over 75 years. They are in the same department as engine block heaters. Check on Amazon, should be between 30.00 to 100.00.
AllegroD
Tank heaters.
deltabravo
Battle Born Batteries has heat pads for sale. They aren't cheap though
