Location of Propane Supply Manifold on Wolf Pup?
KenS999
Hello,
I recently purchased a used 2017 Forest River Cherokee Wolf Pup 16FQ. Does anyone know where I can gain access to the propane supply manifold? I would like to run a dedicated low pressure supply line to inside the living area to supply a portable catalytic heater for boondocking. Does the manifold typically have spare additional unused ports to accomplish this?
Thank you,
Ken
3 REPLIES 3
KenS999
Out the window, if you keep it cracked. Otherwise you could have a bad day. Window, roof vent, if you have one. CO and LP detector is also a good idea.
thanks,
Ken
midnightsadie
great advice,question are these type of heaters safe? wheres all the carbonmonoxide go?
Old-Biscuit
Follow the propane line from LP Reg.....
No there are NOT spare ports
'T' is added for each run from main line to component
You would need to add a line with 'T'----might be easiest at stove top/or furnace as there are in kitchen area
You would have to disconnect one of those supply lines.add a nipple and 'T' then connect both supply lines
Use pipe dope or Yellow Teflon Tape on threaded fittings....none on flared type
