locking up a progressive ems pt30c
riven1950
Did a search but did not find an answer. I know you can't stop a determined thief, but, I looking for a good, simple, hopefully inexpensive way to put a lock / cable / etc. on my new ems pt30c. Any creative ideas?
18 REPLIES 18
Bobbo
A little late now, but that was why I went with the built-in HW30C.
Bobbo and Lin
RoyB
I don't use one yet for my off-road POPUP setup... I probably should be using one with all the additional radio electroics I have inside my OFF-ROAD POPUP setup....
Here is another forum post on same subject:
LOCKING EMS PT30C
Since your shore power cable has to plug into this unit you are required to install this on the camp ground pedestal... Not sure how I would add some sort of security/thief protection on the camp ground pedestal. I bet they would not want your to drill and add something to their outside pedestal. Maybe I am missing something here...
I would probably re-wire between the shore power cable connection and the on-board 120VAC Distribution Panel and add connection there for the EMS unit. This would at least keep it all inside the locked up trailer.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
mlts22
Fairly easy fix:
This plus this will provide a minimum level of security. The anchor basically Superglues on, and you use the cable to wrap around a fixed object. Ideally, use an extension cord between the pedestal and the EMS, so you can tuck the EMS underneath the vehicle. Out of sight, out of mind.
This won't stop a determined thief, because they will snip the lock off with bolt cutters, or force the anchor off, taking a chunk of the Progressive case with it. However, it will stop the skulkers from making a "ground score".
wa8yxm
Mount it INSIDE the RV.. That is the best Idea I can come up with. Outta Sight, Outta mind.
