Looking into Inverters Options
Moomba2002
Looking for options on a 2000 watt inverter for occasional use. I was wondering what other brands people have installed as I know of Xantrex but not sure I want to spend that much right now. Looking forward to seeing some options. Thanks for the feedback.
2017 Ford F350 Super Duty 4x4
Demco Hijacker Autoslide 18k hitch
2017 Columbus 383FB
ExtremeAire 150 PSI 100% Duty Cyle on board air w/4gal. tank
2003 Arctic Fox 1150 loaded except solor
21 REPLIES 21
Artum_Snowbird
smkettner wrote:
Minimum 100 amp hours for every 500w is the rule of thumb that I know.
I am wondering more about the current carrying capacity of the battery itself, not the available amp hours. Can the internals of deep discharge batteries handle high enough current to support the load?
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
time2roll
Artum_Snowbird
Now I understand that the OP wants 2000 watts, and allowing for a bit of a reduction, lets say that is 150 amps at 12 volts to give him 1800 watts.
What is the maximum one can safely extract from 2 Group 27 or 29 12 volt batteries? Would not a battery designed for starting a heavy engine be a better choice than a battery designed for deep discharge but at a slower rate?
And considering that all current comes through both batteries if it is two six volts batteries, what is the maximum current that they can handle safely? Once again, six volt batteries are deep discharge and not designed for high current like starting batteries.
Maybe he is planning on four batteries for a 2000 watt inverter?
Mike
RLS7201
Here is a good place to shop.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Reddog1
Moved from TC Forum.
Wayne
Moderator
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Mandalay_Parr
Looks like you spent a lot on your truck.
You will need a good size battery bank for such an inverter and a generator or converter too.
Jerry
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Mandalay_Parr
Magnum is a good brand.
Jerry Parr
Full-time
2005 Mandalay 40B
2004 CR-V Toad
jrparr@att.net
602-321-8141
Kenwood Radios
